Old 12-02-2012, 02:55 PM
Default Re: Jb weld
Originally Posted by dmess62 View Post
I've never used jb weld before and was wandering if it is ok to use to fill in holes in the frame and redrill and tap. I have a couple that are off a little but not far enough to drill new ones beside it
You can try it but I have my doubts on it working. The JB weld when it sets up will be a different density than the aluminum and one will drill easier than the other. So if you try to drill between the two one will push the drill bit to the other. The only way it may work is to make a jig with the holes in it that you want and clamp it in place to force the the drill bit to dill where you want it. Good luck and let us know how it turns out.
Travis
