Old 12-02-2012, 04:21 PM
kornfed kornfed is offline
kornfed is on a distinguished road
Default Re: Parts Interchange
Very cool thanks for the info they also offer some alum. rear axles with the correct holes for that suspension. they also say for the Man truck so they are also the same in all the tandem trucks?
Old 12-02-2012, 05:05 PM
Yes the axles are the same too. On all the trucks the front axle, transmission, drive axles and suspension are all the same. The trailer suspensions on the tandem axle trailers is the same as the truck suspension. The only real differences are the single axle rear suspension, triple axle trailer suspension and a few of the trucks have a transmission with a guide for the shift rod. The trans with the shift rod guide is the same as the standard trans, it just has one extra hole in the end plate for the 3mm shift rod guide.
