Old 12-06-2012, 02:29 AM
TRUCKMAKER's Avatar
Default Re: D8R +463 in 1/5,6
Hi Dan, here is the link to Roger trailers
http://www.rogerstrailers.com/
I saved the site for that very reason they have drawings with dimensions, hope it helps. The build is coming along nicely.
Old 12-06-2012, 03:32 AM
Hey Dan, You may want to cut the glass to size then see about getting it tempered so it won't crack easily.
Old 12-06-2012, 09:44 AM
D8R D8R is offline
Thanks, did look there on a 50 ton lowboy(CR50PL), scaled down to D8R size (1 to5,6), the trailer alone will be 9foot long! Unfortunatly it looks like the drawing is not so good for detail, have to enlarge it with 1500%, but it will give main messurments. Guess christmas holidays saved behind computer making some drawings.
Steve, I will try cutting the windows first, not sure I can do it, is it specialist that tempers the glass?
Dan
Old 12-07-2012, 05:03 AM
That thin of glass is not difficult to cut if you score it correctly with a good glass cutter. After cut to basic size, you can grose with pliers sand or carefully grind to get the rounded corners then sand smooth. You should be able to go to a glass shop and they could get the pieces tempered for you. I learned how to cut glass at an early age in my grandfather's stained glass shop.
Tags
1/5.6, big scale, cat, d8r, dozer
Currently Active Users Viewing This Thread: 16 (0 members and 16 guests)
