Old 12-18-2012, 04:17 PM
rcman rcman is offline
rcman is on a distinguished road
Default Re: RCMAN's Globeliner 1st custom stretch!
Thanks I meant 77cm I would edit the other posts but I cant
Old 12-18-2012, 04:36 PM
I fixed it and edited my question out of mine as well.
I say go for the 77cm and mock it up to see how you like it. Just drill the front holes and the cab mount holes then assemble the rear suspension to the crossmember and slide the rails in. You just wont be able to put in the two top screws and the long main screw through the center but it will hold together good enough to get an idea of what it will look like. Remember it is easier to make the frame shorter if you want but it is going to cost some time and money to make it longer if your not happy.
Travis
