Hmmm.. deja vu .. this is what I'm just starting to make.. though mine will be bigger.
![]() This will certainly be good for Nate, that topsoil in his basement is absolutely brutal when it's dried out!!! Can't play for more than 20mins & you start inhaling that $#!&!! ![]() Did you drill holes in the spray bar? I was thinking of making a slit in the tube with dremel cutting disc, kinda like spray nozzle tip so the spray pattern fans out in a mist.
