Old 12-29-2012, 06:15 PM
Default Re: For those dusty days on the construction site.
Originally Posted by Radio Control Trucker View Post
Check irrigation sprinkler heads. You should be able to find some small enough to look accurate and yet give you the proper spray pattern that you would hope for. I worked on a golf course with my father for over a decade and I was amazed at all of the different equipment available on the market when it came to sprinklers.
- RCT
I will have to check into that and see what is available.
Thanks
Old 12-30-2012, 06:03 AM
Originally Posted by oztruck View Post
hi guys I built this one a few years ago. Used a wind screen washer pump that worked very well. But the tank was too small. If you really want to wet down an area it takes a lot of 1/14 scale water.
That is a good looking truck. The tank I made holds about a gallon of water and I am guessing it will empty it in about a Minuit. Some things just don't work in scale like the real 1:1 do but it is still neat.
