Jw., good job on the drawings!
One thing that I'm not really sure of is where and what seals are used? |
JW : steel or iron next to brass would be the best choice for your manifold . Aluminum does not wear well .
Madda : O-rings work well for the seals as you should only have to seal the shaft of the rotor and the rotor cap . between the rotor and the valve block , you should have a lapped fit .
This is the only picture that I took of the Volvo's valve assembley. I believe the pistons in this are .550. In mine they are slightly larger at .610.
even with the poor tolerances on the Robbie valves , they don't leak . The rotor just chews up the manifold . When I get back to running steel in the mill , I'll be making 2 , 1 for the loader and 1 for the TD40 .
