Old 01-04-2013, 12:58 PM
cushman cushman is offline
cushman is on a distinguished road
Default Re: Wedico Rear Suspension
Hi Claus,
Thanks for the info, your Peterbilt looks fantastic
Regards Cushman.
Old 01-04-2013, 01:06 PM
Claus's Avatar
Claus Claus is offline
Thanks Cushman, the truck has gone through a lot of changes since that photo and has more changes to come.
One thing I forgot to mention though, if your using the Osswald front suspension you will need to drill two holes in each frame rail.
More recent photo;
Old 01-04-2013, 01:50 PM
Hi Claus,
Thanks for the info re the front spings. The front wheels you have are they Wedico wide wheels ?
Regards Cushman.
Old 01-04-2013, 02:27 PM
Claus's Avatar
Originally Posted by cushman View Post
Hi Claus,
Regards Cushman.
Yes they are, Wedico wheels front and rear. I'm going to be buying three Scale Art rear 3:1 locking diffs, I may also be adding a Scale Art 3:1 front locking diff, building my truck into either 6X8 or an 8X8, I'm not sure if the Wedico wheels and the Scale Art axles are compatible, I may have to go with Scale Art wheels and I really don't want to. I currently have Ruest axles and they will not accept the Wedico wheels without modifying the Ruest axle nuts. There is simply not enough room inside the Wedico hubs to get a tool in there to tighten the axle nuts.
