Body Shop Tech Body mods and tricks of the trade and painting tricks here. |
I'm curious about this as well. I'm subscribing to see what I can learn, but I to would think some type of epoxy would be your best bet. If not that, perhaps you can add styrene ribs, internally, to the styrene pieces you want to attach to the metal portion of the tank, and simply drill holes through the metal, and then run a self tapping screw into the styrene rib. That way it would also be removable, in case you want to make repairs, or paint the part separately.
Nathan |
espeefan that would probably work but i am trying to stay away from screws as if you look at the tanker for the duel truck the sides are smooth with the bolts almost hidden.someone today suggested i use ca super glue with the spray excellerator .i have never tried gluing the styrene to metal before so i am hoping someone here will help me with a solution that will work for me..after all this is THEE place for awesome talent and abundance of knowledge
