Old 01-05-2013, 09:00 PM
1985 kenworth's Avatar
Default Re: gluing styrene to metal
thanks for the info i will for sure explore all suggestions here .i really want to do this right and make sure it will hold whichever way i go
dwayne
Old 01-05-2013, 10:07 PM
Hotwheels's Avatar
Hotwheels Hotwheels is offline
Hotwheels is on a distinguished road
If you try the epoxy test on scrap as I suggested also scuff the plastic side and the metal side that will be joined together with something like 100 grit sandpaper then apply epoxy. I don't think you could pry them apart, it gives added grip. Same principal used in painting real and model cars and trucks. I have bonded other plastics to metal before on different projects and worked great. Let us know whatever method you go with that works best.
