Thanks for the advice I'm planning on laterial braces along with fore and Aft braces as well. This Beast I'm building is really getting heavy with all this stuff I'm adding to it. I'm thinking about two frame set up right now, I can get all the Aluminum channel I want , not sure yet just thinking about it.
John ![]() Last edited by crazy4yachts; 01-06-2013 at 01:51 PM. Reason: adding words |
I think I have found what the Beast is going to be as far as the Chassis goes. Here's my idea, tell me what you guys think ?
Here's some other version I like better.
Ok so I got my RC4WD 6x6 Beast and I'm thinking about buying those scale axles for this build, instead of using the Tamiya rears I have now . These are really scale looking axles and they are not plastic. Plus I can make them all 4-link suspension that would be killer looking compaired to what I have going on now.
John |
John:
Just read thru the build, and I gotta agree, thing is gonna have chassis torque issues, you may wanna consult with some of the crawler guys on this. I also saw that last set of pics with only the 6x6 setup, and the center of gravity looks ~really~ high... especially compared to how narrow it looks. You going to suspend the batteries under the frame? And loved the pic of that Armored HEMTT cab in the last " Maybe this ? " post. I'm thinking of one of those, and with the armor panels, detailing of the cab is minimized compared to a stock Oshkosh HEMTT (and have you looked at the prices of the MAN KAT cabs from Germany? OW. Something else I'd put to MilSpec builders: wheel covers (NOT hubcaps, fool!) Think like the ones on the APC in aliens, or the HEMTT's and such. I can think of a few ways to make them - all involve attaching them to a fancy axle-bolt/cap. Ponder this - a bigger 'nut-head' that has 3-6 micro-bolt holes around the head, and you bolt the circular cover to this. How complicated, and how much a pair? They could be used to 'hide' any rims out there... WhiteWolf, not aiming to thread-jack, - so post a link to a new thread if you can make 'em... |
I know I'm really thinking about doing a double frame set-up. I had to go tall to accommodate the oversize tires I'm using. I'm going to go with CTIS hubs on the wheels to make it more Military looking . Suspending the batteries is a good idea to keep down the CG. Right now this thing weights about 35 to 40 Lbs and I'm not even close to being done. I would like to either scratch build my own cab or maybe have someone build it for me no sure yet.
John |
If these are the tires you want to use, and you want a military truck style, I would suggest making a bigger frame. The problem with staking two frames is they won't be wide enough. So bigger more to scale c-channel aluminum would be better. And instead of lifting the frame to fit the wheels, I would lower the frame to fit the wheels. Like the trucks in the picture, the wheels should be about level with the frame, that would be a good suspension height. Hope that helps a little. And where do you buy your axles from?
-Craig |
