Hey Mike what type of battery or batteries are you using and also what suspension up grades did you go with. I'm looking to do a lot of up grades to my mini Beast as I like to call it. I want to put bigger shocks on it but I'll need to also change the lenght of the 4 link set-up to use bigger tires.
John |
Using a 3S lipo 11 V +/- 5500mAh But as I showed I am using a Leopard LBH3660/8T Brushless -3600kV- Between motor and the old version Tamiya 3speed gearbox from the Bruiser I have this semi automatic transmission from Traxxas, It's more of a clutch system. But it works perfect ! (TWO SPEED W/Reverse Auto Transmission TC3 Traxxas E-max) As a ESC I am using a 150 A with a BEC of 6V 6A Tyres are from RC4WD : Crazy Crawlers 2.2 You can still find them in different stores or on ebay I did cut the foam a little bit and put weights in the rims. Furthermore a used these shocks from RC4WD Spark Comp Shock with Ti Shaft (110mm) They make the suspension a whole lot better ! The originals are to short and to stiff. Then I changed the punisher shafts, I am using the ones from Gmade. Finally I changed the XVD's from the front axle. Broke one (!!??) after my first run, but furthermore these XVD's are stronger and they allow more steering. Mike |
