Old 01-22-2013, 04:04 AM
Acadieman Acadieman is offline
Acadieman is on a distinguished road
Default Re: cuttin aluminum on wood grade power tools NO NO
Originally Posted by doodlebug View Post
I use antifreeze in my big band saw, dont have to worry about it freezing.
And it's free to boot. Down side, it will contaminate welds!
Cheer's, Neil.
Wear gloves as well. We used antifreeze in our machine shop, and our machinist got severe skin infections. The stuff is nasty.
Old 01-22-2013, 06:23 AM
Haven't had that occur yet, but like to wash up often! Tried soluble oil, froze solid:-(
Cheers, Neil.
Old 01-22-2013, 07:13 AM
You must have held it wrong or the wrong type blade. You can even cut steel with a chop saw but blade won't last long. Just look at the air clamps from all the mistakes I've been cutting thin aluminum channels with cheap Delta chop saws for over 32yrs. I had one break a casting once. I have several big saws for cutting metal and for most of my notching I use one of my 5 Delta Rockwell table saws. The only modification to the table saws are a steel table insert to accommodate the smaller diameter rip blades I use.
I also cut architectural bronze extrusions on all of my saws. Only problem is the chips really hurt so you have to cover up hands neck and face.
