Farm Tractors and Implements Discussion of farm equipment |
so you can't get just the wheels and tires? I'm trying to navigate that site with my phone :/
very nice build. we need a north american supplier of this kind of stuff...... |
You may contact Andreas Blocher and ask if the tires are available...
But you may also find some with nearly teh same dimensions in the U.S.....at Dakotah toys in SD. The "Trelleborgs" have nearly the same diameter.
regards, Frank |
Anxious to see a vid of that machine! how wide is it from the center of each tire?
Hi together!
This week I took some pictures outdoor... ![]() ![]() ![]() @gauthib12: dimensions will follow...I´ll have to check them in the workshop.
regards, Frank |
As promised some dimensions:
length: 390 mm wide: 210 mm hight: 225 mm wheelbase: 205 mm ground clearance: 25 mm Tires: 123 mm diameter, 56 mm wide Pictures "at work" will follow... regards Frank
regards, Frank |
Pretty cool pic with the 1:1 in the back.
