Old 01-26-2013, 04:28 PM
Default Re: Kenworth 850 Off Highway
Looking good! The detail is great. I like how you put on the track bar and radius arms. Bolted them up, just like the 1:1 truck. What kind of servo are you going to end up using? Maybe a dual servo steering set-up is in order?
Old 01-26-2013, 04:30 PM
Thanks, I use a 645 in my Euc and it has no troubles. The linkage ratio's are almost the same on this so I think one of them will be fine.
Old 01-28-2013, 05:35 PM
I wasn't happy with the shape of the upper window area so I cut it out and made a new piece! There's also a few other little things but nothing really note worthy.
I'm not sure if I will put the visor on the finished model or not but I thought that I should make one just in case...
Thanks for looking!
Reg
Old 01-28-2013, 06:18 PM
Pippoe Pippoe is offline
Pippoe is on a distinguished road
What a beautiful work! Your steering servo seems almost tiny for such a huge machine. Will you add a heavy duty servo?
Cheers
Pip
Old 01-29-2013, 04:39 AM
Cheers
Pip
I will be using a standard size high torque servo. This one is just being used for mock up.
Old 01-29-2013, 04:45 AM
ihbuilder's Avatar
Reg , you should be good with the 645 servo . thats all I have on my mack . It fusses a little sitting still loaded but running no problems .
Old 01-29-2013, 05:40 AM
Yeah I think so Steve. Use the same in the R18 with no problems and it runs a 6lbs battery right over the axle. This trucks steering is very similar and I doubt if it will be any heavier on the nose.
