#141
Wow - very nice!
#142
One sweet Pete...
#143
Thanks Oz , Izzy n Brick
![]() If you guys like, I know we're on the right track ![]() ![]() Mario |
#144
Hey all !
So I'm off work because I hurt my back.... Well sitting on the couch ain't helping, trying to work on Susan's truck is not working out so I'm going crazy and found something to do for a few minutes which didn't hurt.... ![]() ![]() ![]() http://youtu.be/xK8bR_DKh1g |
#145
Black passion looks amazing!!
Keep up the good work |
#146
Hey Mario,Susans truck has came a long way looks real good cant wait till Indy
#147
Thanks for the compliment Buzzy and ya Chris, I cant wait till indy
![]() ![]() I feel like I brought a knife to a gun fight last year with just one truck and 3 trailers.... gonna be different this year, 3 trucks ( if I get the Wedico together ) 5 trailers and a Liebherr 574 loader ...... hmmmmm, yup. I have a problem, definitely addicted ![]() ![]() ![]() anyway, going crazy laying around the house the last few days and feeling better today so I got some work done on Black Passion! ![]() ![]() I really liked how my MFU mount worked on my truck so I did the same on this one. No glue or screws required, just a wedge fit. ![]() and thanks to the higher sleeper i was able to add a shelf for the SS tronix kit and still have easy battery access. Also high enough it cant be seen through the rear sleeper window. ![]() ![]() ![]() heres the mfu switch box mounting and the chassis wiring. ![]() ![]() ![]() so thats it for today. Just need to make a few more connections, the speaker , put a battery in and test it out tommorow! the done list is getting longer than the to do list on this build ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() thanks for looking , all comments welcome Mario |
#148
great job Mario as for indy Boss said I can only take what will fit in the Jet
#149
![]() looks FANTASTIC Mario! finally a pete done with the headlights in the right spot (with the exception of brians 2) those dual round dont look bad mounted low and forward like that, but ive never seen them mouted there. looking at the pics, its like S&M traded in an old ruck to get the BOSS a new Pete! LOL |
#150
![]() When you bring something like a 990 , that's like bringing a 50 cal . No other ammo required! ![]() ![]() ![]() Glad to hear you plan on attending, can't wait to see how many buckets to fill Susan's 3 axle end dump ![]() Thanks Goose for the thumbs up. The headlight placement was tricky but I knew to get the look right they had to be low as possible. I never did take pics as I installed them but they are mounted to the stock grill with 2 mm bolts, nuts on the back side and some thread lock. I was able to wire and install complete on the grill first then mount on cab. Getting these lights straight and perfect is almost impossible. ![]() ![]() The driver side turned out perfect. The passenger side on the other hand is just a little off and not much I can do. The mould of the plastic is off a bit, it's where the lamp group meets the bracket is not square and has a slight tilt and twist. I'm being fussy though, it's not like the lights are pointing off in all directions and ya really gotta look to notice so I quit filing and shimming and mounted the thing before I screwed something up! ![]() ![]() ![]() Mario |
#151
Well, getting closer now. Tranny noise issue is fixed. Radio all set up and working great, chassis lights ok.
So it was time to test the 5th wheel operation. I was nervous at first. Wasn't working near as expected ![]() ![]() ![]() Did some more bending and tweaking of the rod and now got it to this point. Here's a video. I need opinions on if the latch is closing enough or will I have issues? No matter what, I refuse to have the arm come up through the deck plate! Worst case scenario is I put a longer arm down under the frame rails and come up with a new linkage ![]() http://www.youtube.com/watch?v=UhXi-iCOSmU Thanks for looking and all comments welcome ![]() Mario |
#152
From watching the video a couple times I see one problem and here another. That servo should have more travel then that so you might want to check your end point adjustments. I can here the servo chatter when it is in the open pos so that tells me the servo wants to go farther but something is stopping it so I would check to make sure the rod is not binding somewhere. Remember as the rod is pulled back by the servo it is going to go down as well.
Travis
AKA "00" Biddle RIP FreddyGearDrive 2-12-59/12-19-11 |
#153
Thanks Travis , yes I agree not much travel... End point adjustment? How do I do that? I ran through the MFU SW1 setting . What else can I do to increase servo travel? Can I get a micro servo with single direction with more travel if I have too?
Oh yeah, I think I'm a couple splines off neutral position and the rod knuckle is catching on the cross member hole. Need to file down the knuckle a little smoother. Last edited by Supermario; 01-27-2013 at 11:34 AM. |
#154
I guess I would need to know what radio your using, the end point adjustment should be in the radio.
Travis
#155
Oops, lol. I have a airtronics VG600 radio and I see the endpoint adjustment screws. Correct me if I'm wrong but 5th wheel means elevator correct? |
#156
Travis
#157
End point on elevator is at max. I adjusted the rod, smoothed the edge of knuckle and all is quite with the servo now. I tested the hook and unhook on my flatbed and besides the fact this truck stands a little taller than mine and I needed to add a little thickness to the leg pads, it hooks and unhooks great. Indoor testing is one thing though, wont know till spring when I get on some outdoor terrain and speeds if it may come unlatched or not.
Once again Travis, thanks for the help and info ![]() ![]() ![]() Mario |
#158
You are welcome, that is what this forum is all about helping each other enjoy the hobby.
Travis
#159
Hey all ! S&M trucking now has a new loader!
![]() ![]() I ordered this machine on Jan 4th. It left Spain on the 11th and arrived at my door on the 29th. That's not too bad for shipping time. I'm impressed. Couple things I'm not impressed with..... At some point in its travel, the box must have been left upside down because when I pulled it out of the box there is hyd oil all over it ![]() The guy has great skills to do this conversion but needs to work on his packing skills. Oh, one other thing. I purchased the lipo battery and charger with the loader but the AC cord it comes with has a plug which looks more like a sex toy than something you plug in the wall! ![]() Lesson learned.... Never buy a charger or anything you expect to plug into the wall from a guy on the other side of the ocean ![]() ![]() ![]() Pics are coming..... Have to finish cleaning the hyd oil off of it first ![]() ![]() Mario |
#160
Can't wait to see the Loader Mario.
Currently Active Users Viewing This Thread: 13 (0 members and 13 guests) | |
