I wasn't happy with the shape of the upper window area so I cut it out and made a new piece! There's also a few other little things but nothing really note worthy.
I'm not sure if I will put the visor on the finished model or not but I thought that I should make one just in case... Thanks for looking! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Reg |
What a beautiful work! Your steering servo seems almost tiny for such a huge machine. Will you add a heavy duty servo?
Cheers Pip |
I will be using a standard size high torque servo. This one is just being used for mock up.
Reg , you should be good with the 645 servo . thats all I have on my mack . It fusses a little sitting still loaded but running no problems .
Yeah I think so Steve. Use the same in the R18 with no problems and it runs a 6lbs battery right over the axle. This trucks steering is very similar and I doubt if it will be any heavier on the nose.
Started on the rear suspension today... Still a lot to do.
I made a little more progress on the rear suspension and frame today. It takes a long time to machine all these little parts when you don't know what you're doin! I think I am learning as I go though which is good!
