I will be using a standard size high torque servo. This one is just being used for mock up.
Reg , you should be good with the 645 servo . thats all I have on my mack . It fusses a little sitting still loaded but running no problems .
Yeah I think so Steve. Use the same in the R18 with no problems and it runs a 6lbs battery right over the axle. This trucks steering is very similar and I doubt if it will be any heavier on the nose.
Started on the rear suspension today... Still a lot to do.
I made a little more progress on the rear suspension and frame today. It takes a long time to machine all these little parts when you don't know what you're doin! I think I am learning as I go though which is good!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Reg |
wow looking awesome Reg.. some nice peices you have made there
Thanks Jason... you'll have to come over and take a look!
