Old 02-01-2013, 02:47 PM
catmack catmack is offline
catmack is on a distinguished road
Default Re: 990 cat loader
I'm gonna have to build low pro mining equipment for my crawl space. At best, 18" is all I have at the high end. It would be a great project though. How heavy is the loader IHBuilder?
Old 02-01-2013, 04:29 PM
ihbuilder's Avatar
OK official weight 46.6 lbs without the cab finished . I guessed about 40-50 lbs awhile back not to far off ( I think I pulled somethin ) I used to throw 50 lb seed, fertilizer, and lime bags up on a hydro seeder for years so I guess I got a feel for it
I decided to go through with the basement dig can't think of any logical place to store my coal unless I start another building I can just see the township beside , I got some new machines coming on line this year I need a good proving ground .
Old 05-27-2013, 09:45 PM
ihbuilder's Avatar
started fixing another weak link today . I kept having issues with my valves sticking open and leaking The culprit p---- poor tolerances in the valve heads . The leaking was coming from a 6mm ID oring on a 5.8mm OD shaft So Made new 1's out of brass . 3-4 hours setup and tweaking and 1hr run time tops between the lathe and mill .
old
new
thanks for lookin
Old 06-16-2013, 10:25 PM
ihbuilder's Avatar
whew a little time in the shop with the cad off and the mill off Did some rearranging with the hydros and electrics . now I can use 2 bats and keep them under the hood . Also no more leaky valves the operator got a bench seat though
all nice and tucked under the hood
