Old 02-06-2013, 01:32 PM
crazy4yachts crazy4yachts is offline
crazy4yachts is on a distinguished road
Default Re: Need ideas for suspension lift
I know I'm really thinking about doing a double frame set-up. I had to go tall to accommodate the oversize tires I'm using. I'm going to go with CTIS hubs on the wheels to make it more Military looking . Suspending the batteries is a good idea to keep down the CG. Right now this thing weights about 35 to 40 Lbs and I'm not even close to being done. I would like to either scratch build my own cab or maybe have someone build it for me no sure yet.
John
Old 09-11-2013, 06:22 PM
nutmag nutmag is offline
nutmag is on a distinguished road
If these are the tires you want to use, and you want a military truck style, I would suggest making a bigger frame. The problem with staking two frames is they won't be wide enough. So bigger more to scale c-channel aluminum would be better. And instead of lifting the frame to fit the wheels, I would lower the frame to fit the wheels. Like the trucks in the picture, the wheels should be about level with the frame, that would be a good suspension height. Hope that helps a little. And where do you buy your axles from?
-Craig
