Thanks very much guys, you all make me feel like I'm doing a good job so thanks!
I spent the day today making hubs for the rear wheels. I felt like I was listening to Tony Beets telling Parker how to look for gold on Goldrush....Drill holes, drill holes, drill holes! By the time you center drill them all and then drill them to size it's quite time consuming! I think they will look pretty sharp though when finished. Nate, My plans have been to run either HPI diff gears like I did in my Euc, or else use cordless screwdriver motors on each wheel. When I finished machining the hubs tonight I was able to try a screwdriver motor and I stripped it in my hands so I guess I will be using the HPI gears. The diffs in these trucks are quite complicated so I'm not really looking forward to it but I guess I have no other option.... ![]() ![]() ![]() ![]() ![]() ![]() ![]() Reg |
come on , stop procrastinating and get them done
![]() ![]() ![]() ![]() ![]() ![]() Oh great job on the hubs know what you mean on the holes ![]()
The diff sets that I have don't have the cups on them. The axles(self made) slide into the spider gears. I'm not really to concerned with making that part of it work but the Clark diffs use a seperate gear train to offset the driveline from the pinion shaft and that's what I'm worried about. I don't have a good selection of gears for that and neither do the local hobby shops, not to mention that they want around $10 a piece for them and I don't know what I need for sure. At any rate I will figure it out, it will just take some time. I may have to buy a couple new drills and steal some gears... The drill drive that I will be using for power will put around 8000 ounce inches of torque to the axles in low gear so it has to be very strong!
Reg |
I see , I'm doing the exact with the truck rears I'm making for the 14th scale . I was trying to use the tamiya insides but not sure they will work . I have torn they're pot metal gears apart on my heavy haul tractor . You'll have to look beyond most local hobby shops for the right stuff . I found this place , http://www.qtcgears.com to get my id ring gear for my twins . they're close in price as the 1 Ari gave me a link to .
A lot of drilling and indexing but looks great! Did you tap each hole or use non-threaded bolt heads or what? I have a similar situation with my Payhauler hubs that require wheel studs with clamps and nuts and am always looking for ideas on different ways to do things. Your craftsmanship is amazing!
Big iron is awesome! |
Thanks for the link Steve. I'll have to see what I can dig out of my "collection" but if I can't find anything useful I may order from them.
Thanks Ken, The holes are just drilled and the bolts pushed in. No threading! I know what you're saying with the wedges to hold the wheels on but I won't be doing that. I think my plan is to just bolt through the rim into the hub on these and just fake the wedges. |
