Old 02-19-2013, 03:33 PM
Default Re: Kenworth 850 Off Highway
Spent a little time this afternoon on the exhaust. Got the pipes hooked to the mufflers and the heatshield made so that the passenger doesn't get burned when they bail out!
Reg
Old 02-19-2013, 04:20 PM
pumptech's Avatar
pumptech pumptech is offline
Awesome metal work as always Reg
Old 02-22-2013, 03:10 PM
I've been working on the diff housings on and off for a few days now. Many things have not gone my way so far. The first thing to go wrong was a broken bandsaw blade before I even had the diffs cut out. I managed to TIG weld the blade back together well enough to finish splitting the block in two but not a permanent fix by any means. I had wanted to do a lot more cutting to save time but the weld was starting to crack so into the mill they went. After about three hours of cranking handles as fast as I could I was spent and soaked with sweat so I called it a day. The next morning I was off to town to buy a replacement blade... When I arrived at the first store I quickly found out that they had every blade imaginable EXCEPT the one I needed. So off to the next place I went only to find virtually the same situation there. They did have one that had more TPI so I reluctantly purchased it, made a quick detour to buy some cheap cordless screwdrivers(you know, future projects...) and home I went. After arriving home I quickly installed the new blade only to find out that it was a no-go on 1 3/4 aluminum. At this point I just carried on machining for a while until I finally became frustrated from shop vaccing chips off of the floor and re TIG'd the blade. If I had done that in the first place I would have saved myself at least and hour on the mill. Anyway a number of other patience testing moments have happened too but this story is already too long... I did have my cordless drill spinning the rotary table while I was milling today though...at least that was fun... until the clamps let go of the housing and....$#%^^#%
I almost have the "easy part" done. Soon I can start on the pumpkins.
Thanks for listening?...or looking?
Reg
Old 02-22-2013, 03:20 PM
wolfws6's Avatar
wolfws6 wolfws6 is offline
wolfws6 is on a distinguished road
Man, those are a work of art. Tremendous pieces you have made!
