Old 02-24-2013, 04:15 PM
Default Re: 1950 Kenworth Needlenose
Time for a weekend update! Work continues on the tank saddles. I have them to the point where I only need to drill one more hole, and then make the straps. The straps will be attached to the upper mounting ears, at the top, and then hopefully I'll have a tension screw to pull the strap tight, at the bottom of the saddle. Just like the real thing, only smaller!
The mock-up tank is just a piece of tube. It's the correct diameter, but hopefully I can have someone make me a proper set of tanks, that will look nicer. Hopefully no one is getting tired of looking at the same parts, as they evolve.
These little buggers proved to be more time consuming then I first thought. But this is why I get bogged down with the details sometimes! I think the work is worth it though.
