Old 02-24-2013, 06:59 PM
Trucker47's Avatar
Trucker47 Trucker47 is offline
Trucker47 is on a distinguished road
Default Re: Possible Solution For Tracked Equiptment
Originally Posted by dirtpusher9 View Post
Chris, that looks really good. Are you going to do a dozer pad as well?
Thats the plan! If it all works out my plan is to make tracks exactly as people would want as long as somebody will buy them cause even though I'm not trying to make a business out of it I don't want to have my money tied up in some track pieces just sitting here because nobody needed them.
catmack,
Thats exactly what I was thinking, if I had a set of links that could be used with any track pad you want then it would make things much more simple.
I would like to use stainless but its not cheap! so probably will be going with just a standard carbon steel that the machine shop would have, not too sure on the exact compound.
I'm not too sure on the size of the machine in the picture, it was just a picture Azonic sent me to use as a reference
Old 02-25-2013, 04:56 AM
A question about material sticking to the pads. Would spraying the pads with something like Pam, the non-stick cooking spray or some silcon-based spray, reduce the problem?
