Old 02-27-2013, 05:07 AM
kaptain Jack's Avatar
Default Re: servo motor
With respect to servo, I removed the limit pin and now when you push the stick on the radio,the motor turns in one direction,until you change the position of the stick and then it goes the other way until you let go.When the control stick is in the middle (neutral) there is no current to the servo.
