Old 03-02-2013, 02:03 PM
CustomRCmodels's Avatar
CustomRCmodels CustomRCmodels is offline
CustomRCmodels is on a distinguished road
Default Re: Driven front axle options?
Originally Posted by WhiteWolf McBride View Post
Travis: (or whomever has done this, like Willy & Joe)
What about the flanges on the axle casing? Do the casing halves that are being used have the flange/edge that overlaps (malke side?), or the other one? I ask as if it needs removal, it can be used as an alignment assist, right?
As for 'alignment', to assure that the 'throughput' pumpkin matches with the central piece, and the gear-mesh inside is ok, you just bore out the screw-holes (as you'll either have two bottoms with no access, or two tops with no thread to grab), and use long bolts and nuts instead, and it'll line up sufficiently well?
WhiteWolf
No cutting required . You just use the male housing (no lip ) part from a straight input/output rear axle and replace that with the non-input/output housing on the TLT-1 axle . Plain simple bolt on .
(Wild)-Willy
CustomRCmodels
Old 03-02-2013, 02:07 PM
You right Willy I was just giving the option to do it from available parts from a place like tower hobbies who doesn't carry the semi axle housings. But you right if you have the other housing there is no mod needed just bolt it together.
Old 03-02-2013, 02:26 PM
If you get 2x TLT-1 axles and 2x center axles ( from a 3 axle truck ) , then you have all the parts for the swap without having to purchase the extra axle housing ( a-parts 0005467 + pinion-gear ) , since then you just use the left over housing half from one TLT-1 axle and fit that as last rear axle . In that case you also would have to do some cutting , but not that much , to fit it together .
(Wild)-Willy
CustomRCmodels
