Old 03-02-2013, 02:13 PM
CustomRCmodels's Avatar
Default Re: Driven front axle options?
Originally Posted by WhiteWolf McBride View Post
Travis: (or whomever has done this, like Willy & Joe)
And lastly: how well do the TLT & Semi axles compare width-wise (assuming the same rims/tires all around)
WhiteWolf
As for the rim-offset , lock at my Krupp ( at the bottom of this page )
You use the rear inner rims as front rims
http://www.customrcmodels.com/Tanks/id86.htm
(Wild)-Willy
CustomRCmodels
Old 03-02-2013, 02:26 PM
Willy:
My imagination, or is the front actually a little narrower than the outer rear axles? As I've got a semy with stock rear width, it'll help me tell if the deed
is not only do-able, but would look decent enough under the body...
Thanks for the assistance,
WhiteWolf
Old 03-02-2013, 02:37 PM
Willy:
WhiteWolf
The fronts line up with the outer rears . Its just an illusion from the angle how that photo was taken . For a better comparison here with a King Hauler body :
all-wheel-drive rig , but with bigger and wider tires .
Therefore the front tires stick out from the fenders ( and the rear is much wider as stock )
http://customrcmodels.com/Trucks/new_6wd_project.htm
with stock semi-rims and tires they would be just covered by the fenders
here is a good photo from Travis's Mack :
(Wild)-Willy
CustomRCmodels
Old 02-20-2016, 01:31 PM
SmallHaul's Avatar
Is there a driven front driven axle with remote locking diff and complete disconnect? Or are they all open and locked only?
I have setup some wedico metal axles that can do this and it is a nice feature.
Scott
"No load is too Small"
Old 02-20-2016, 04:04 PM
Der Getriebedoktor refurbish Tamiya axles. A big pluss is that you don't have to buy new rear axles, since they have the same gear ratio.
If you want to spend som money, these are awesome: http://www.wtbcar.com/shopping/index...product_id=192
Old 02-20-2016, 10:39 PM
SmallHaul's Avatar
So both of these axles have 3 positions...locked diff, open diff and disconnect front axle from being driven?
I don't really see how the guy that mods the tamiya axles could completely disconnect the front axle from being driven/powered? I have it bookmarked on how to to lock and unlock the diff.
The second link looks like a Lesu axle (maybe re-branded?) and going by the photos i have found it looks like it just locks and unlocks the diff and does not completely disconnect the front axle from being driven.
It would be nice if a tamiya tlt axle could be converted to work the way that i want it to.
Scott
Old 02-21-2016, 06:12 AM
Then you need at transfer with disconnect: http://www.veroma-modellbau.eu/shop/...etriebe-1.html
