Old 10-06-2010, 04:48 PM
Snowman's Avatar
Snowman Snowman is offline
Default Re: Nick's 379 build
Originally Posted by sneaky-pete View Post
I will send you a pic of what I did w/explanation when I get home tonight.
Hey, thanks man!
Nick
My Peterbilt build thread:
Old 10-06-2010, 09:01 PM
sneaky-pete's Avatar
Master A-Modeler
Hey Nick,
This is how I fit the wedico tires to my meir wheels.
First I ground down the lips on the inside with my bench grinder(be careful not
to nick the outer rim).
In this pic,I cut off the long portion of the hub so I could use my hub covers.
Then I wet the tire to help slide it on (this helps when you are doing a bunch of
tires).
When you get the tire on the wheel it will be lop-sided.
You will need to work the tire around the wheel with your fingers.
Then you are done!
Troy
Old 10-06-2010, 09:12 PM
Brian in PA's Avatar
I'd rather be truckin'
That looks great Troy. There is no mods to the tires?
Brian
Old 10-06-2010, 09:15 PM
Master A-Modeler
Brian
Sorry I forgot to mention that I did not modify the tires.
Troy
Old 10-07-2010, 12:33 AM
Brian
someone can also make wheels to fit he just did 2 tonight
Troy where you get those hub covers ?
looks good , Nick
IHSteve
Old 10-07-2010, 12:50 AM
bigford's Avatar
bigford bigford is offline
you guys lost me here!
you have a king hauler with wedico rims and whos tires??
whats the reason for this setup
Old 10-07-2010, 01:00 AM
Claus's Avatar
Claus Claus is offline
Nope, Meir wheels, Wedico tires, I believe they are going for the low-profile look.
Old 10-07-2010, 08:16 AM
Master A-Modeler
looks good , Nick
IHSteve[/QUOTE]
Here ya go Steve!
http://www.verkerk-modelbouw.nl/inde...n/Page2892.htm
Troy
