Old 03-03-2013, 06:14 AM
pugs pugs is offline
pugs is on a distinguished road
Default Re: Solidworks help... Track pad
Select a face to put cuts or bosses on and then click the view normal to button (looks like an upward arrow with a wide flat base. Then click on new sketch, draw the shape, then cut or boss it up. If there is no flat surface where you need to build a new sketch then you will have to build a new construction plane through one of several methods, all are pretty self explanatory.
Jeff
