Old 03-06-2013, 04:07 PM
kdz76's Avatar
kdz76 kdz76 is offline
kdz76 is on a distinguished road
Default Re: Newbie - Trailer Axles Help Needed
I would try some flanged bearings with the inner diameter the same as your current axle and the outer to be determined by the hole you can drill in your blocks.
Old 03-07-2013, 06:00 AM
bigdogrod bigdogrod is offline
bigdogrod is on a distinguished road
i built a boat trailer with semi trailer axles, i cut the axles in the middle, then used some brass tube of a little larger diameter than the axle to get the with needed. slide the plastic housing into the tube, glue and go.
