Old 03-14-2013, 08:20 PM
Default Re: S&M Trucking open for bizz nizz !!!
Mario,
Are you only running ONE 32 guage wire inside the sleeve?
I know the solution, and you're gonna kick yourself - don't use heat-shrink. Use some casing from a solid-wire a few guages up, like telco wire. Just strip it off the other stuff, and then thread the mag-wire into it.
Heck, that white 4-conductor stuff has yellow, black, red and green casings ya can use.
I've been using this method for other guages for years when I dinna want to use heat-shrink 'cause it would melt the wire casings, or sommat nearby. Also use it for scale wire-loom, handles, and other things...
WhiteWolf
