Old 03-16-2013, 01:48 PM
ptebbe ptebbe is offline
ptebbe is on a distinguished road
Default Wiring Diagram, modifications
Here is the standard wiring diagram. Note that the ESC and the Diesel Engine Noise module are both contained within the silver box with the rheostat adjusters on the top.
The following changes have to be made:
-get rid of the control board at the end of the ribbon cable (not the switch board)
-get rid of the lighting control boards front and rear
-hookup the speaker as shown
-BRAKE light: connect the green/yellow cable to both brake-light bulbs, wired in series and then connect into a positive battery lead.
-SOUND: white wire connected to an electronic switch (I used Dimension Engineering PICO switch) then patched into negative battery lead.
-REVERSE lights: 2 bulbs wired in series with red/black leads from the drive motor plus a diode on one lead (so they only light up when in reverse.)
Headlights are controlled by a Dimension Engineering DeLight controller...LEDs were used instead of the included bulbs.
Manual switch for hyrdraulic pump was replaced with a DE Battleswitch.
