Old 03-18-2013, 01:50 AM
D8R D8R is offline
Default Re: D8R +463 in 1/5,6
Dan,
Have you tried just opening the valves up that are there now? You could do some smarts with the servos... Its gotta be easy to run the receiver and servos without the motor?
Cheers,
AP
Hey Dan, do you have room to tee in a couple of high pressure ball valves
On the drive motor's? That would give freewheel to the beast!
Cheer's, Neil.
Thanks guys for the suggestions. Have not filled up system yet, don't want to stress hyd motors before they have oil. Today it's almost impossible to move the machine if not gears are removed.
Neil, there's not room for anything more inside, it's cramped!
Will test these when filled up, until then go without gears.
Yes Lou, have tried to follow what's shown on tube. I know of one BIG norwegian D11 (1:4 750kg=1600lbs) that has not been seen there yet, guess that will come when snow/winter is over.
FOUND IT:
http://www.youtube.com/watch?v=-MxKX_bhwRI
/Dan
Tags
1/5.6, big scale, cat, d8r, dozer
