Old 03-23-2013, 02:04 PM
rc_farmer's Avatar
Master Builder
Default Re: MORPOWER pump & valve
Ed, it s funny U should post this now, Ed in Stl and I were just talking about ordering one of these this coming wk. Interesed to see how they work. I did notice they have changed thier website.
They are in Tawain.
Giving up is not an option!!!
Rob
Old 03-24-2013, 04:47 PM
rockNmayhem's Avatar
They are in Tawain.
Rob I should be receiving mine tomorrow or tuesday as it's been a little behind with the weather but I will be glad to let you and Ed check it out in April at the show. I hope to have it in a loader by the show but if not I will still have it to play with. I asked the company when purchasing the pump and 3 valve block about the power draw and they gave me a straight answer saying that the peak amp draw was 9.143-9.200 at 12V and a continuous draw around the 3-4 amp range when not overloaded.
Now I know thats still a little much but I'm going to give it a try on a 5mAh lipo and set the pump only to engage with the servo throw so I can save batteries and also hopefully keep everything running cooler.
I'll keep people updated with what I find out as well.
Ed hope to see some projects coming along with that setup.
Tyler
~Tyler~
RockSolidCustoms
Old 03-25-2013, 05:55 AM
JAMMER JAMMER is offline
The case says DC 7.2 Volts 1500 RPM and the advertised pressure is 298.78 the gears are 3/8 inches in diameter and 7/16 inches tall and no relief valve. the drive gear has an O ring on the shaft on it and it is recessed in the case. the pick up is a hose connector with out the nut on it opening that up would help. I would say a bigger motor with more RPM and larger pick up and the pressure would go up. Ed
Old 03-25-2013, 06:02 AM
Joe the motor says Dc 7.2 volts 1500 RPM. there is no relief valve and the pick up is a hose connector with the nut off. The gears are 3/8 inches tall and 7/16 in diameter. EMS is the deliver people. I would say with a larger diameter pickup and a bigger motor with more RPM the pressure would go up. Ed
