General Discussion A place to post off topic discussions. |
I was pulling 5amps on a 20 turn motor with the leim pump... so sure, its possible! going to a 45t torquemaster cut it to 1200mah every 15 minutes (havent amp measured that yet). soo...over an hour on my battery. my servos suck quite a bit of juice as well.
20bars at 7v. interesting! that will allow you to run about 8000mah 2s in the same space as a 6000 3s. |
Joe if you are unhappy with the motor just change it as you can see there is a coupler between the motor and the pump. The pump turns sort of hard witch tells me it the tolerances are tight the gears are a lot big compared to wedico and other german pumps except Jung I put the pump back together so no measurements of the gears right now. Nathan they are in Taiwan and they make a single valve for there landing gear a 3 and 6 valve. In case anyone wants to know they ship quick I ordered on the 19 of March and got it yesterday came EMS. I like the valve body it comes with servo and has nut fittings so you can use a wrench to tighten the lines. They also have quick couplers with shutoff on both sides. Ed
