Old 03-25-2013, 10:16 AM
Default Re: LR634 has arrived!
Guys, where is the best place to buy one of these? TTM, Permacon? Somewhere else? I just want the loader kit, with a hydraulic retro-fit, and the track drive. Seems like it's going to run about $3,400, plus shipping, with no radio electronics.
Old 03-26-2013, 11:46 AM
Mo,
Have you considered getting a set of the Goldhofer bed-extenders from EC-M? I'm considering it, but I'm hoping someone has better images of the product...
http://www.ec-m.ch/preisliste.html
Some of the model images have other angles, but the only other pic thats halfway decent is on this page down toward the bottom...
http://www.ec-m.ch/modelle.html
Anyone got a set, or able to talk to 'em and ask for better pics of the pieces? I'm sure Mo and others would like better shots, eh?
WhiteWolf
- can't wait to see your Goldie build...
Old 04-03-2013, 04:00 PM
MoRockN's Avatar
MoRockN MoRockN is offline
MoRockN is on a distinguished road
Sorry Man, I somehow did not see this. I ordered mine from der-getreibedoktor.de , he will get the package price for you and send you the info before you pay for it. Just email him and tell him you want the same set up I have. He will give you a good deal if you mention my name.
Good luck!
Ayoub
If you got it, a Trucker brought it....
Old 04-03-2013, 05:21 PM
Mitch Mitch is offline
Mitch is on a distinguished road
No overnite shipping. They told me that it would be 6-8 weeks (likely 2.5 months) to get everything. We'll see what happens. I plan to powder coat the metal parts once I make sense of it all. Also, I found that the metal tracks need a little work to move smoothly. I had to drill out each pin hole a bit, and mill the inserts. They worked fine after that , hopefully, they have addressed this. Also, I ordered extra, because they are brittle and tend to break.
Mitch
Mitch
Old 04-04-2013, 12:37 PM
Good luck!
Ayoub
Ayoub, thanks! I'll give Doc Gear a look. By the way, any chance you could share some photos of the model's internals? How you have your battery, speaker box, ESC, and sound unit crammed in there? It looks like it would be pretty tight. Is there more room then it appears to have? I'm just trying to get an idea of where the components fit. Do you think a standard sub-C 7.2 volt battery pack would fit with everything else you have in there, or is it small LiPo packs only?
I'm sure you haven't really got a chance to work the model, but any idea what sort of run times you have been getting?
Old 04-06-2013, 05:07 PM
MoRockN's Avatar
I will post some pictures when I get home to show you how mine is set up, you can run any type of battery depending on how you place everything. I'm used to RC race cars and truck where we cut all the wires and leave no slack, but in these machines I just don't like to cut any wires just in case I want to move things around, the problem with that is the freaking wires take up a lot of space.
Old 04-07-2013, 10:56 AM
MoRockN's Avatar
Ok here you go, now this should give you an idea how I did mine, they tell you to glue the back section to the body but I did not, it's something that I am happy I didn't follow in the manual. It gives me easy access to the on/off switch , battery change and just makes life a lot easier.
Now you can see how everything is laid out, if you wanna use a sub C battery, you would swap your electronics when my battery sits and you can lay your battery when my electronics are right now, so be creative. One thing, nothing should be sticking out above the top black line on the chassis.
You can see my battery right there on the right, the black spektrum thing. Now I have a replacement for it that's $23 from hobby king .
Now the wiring is done by my friend Eddie , he's a freaking wiring genius and did move everything around to make it fit like it is now.
The run time on that battery is around 1:45min. Mild use that is.
Old 04-18-2013, 10:14 PM
buzzy16 buzzy16 is offline
buzzy16 is on a distinguished road
are you saying you 1 hour 45 minutes out of the battery?
I'm seriously considering getting one of these, after a lot of saving that is.
would you be able to tell me the bucket reach?
thanks buzzy.
