1100kv, hmmm, that's quite a bit... do you have the epa turned to 50-60% max? Are you running 10cell or 3s?
What were the specs of the other brushless motor & why did you change it out?
The original replacement motor from Leimbach is spinning on 12.000 RPM at full speed. That equals to a 1080kV motor using 3s LiPo (as I am).
I´ve set it up to run on 30% without load, and up to 65% with fully open valves. All four functions are mixed with the pump using the radio (Spectrum DX10t). The old motor had similar specs, but it had some bad bearings. The new motor is bigger, thus I expect it to have more torque. I´m looking forward to really try it in the dirt ![]()
