5" dia? The tractor lug for the wheel loader is solid rubber & the other has thick sidewalls, both 5" outer dia. Inner diameters for both wheels are 60mm or 2.4"
This foam Reg, would it carry 80lbs on four tires without excessive squat? ...basement floor is anything but flat! I think the oak donut might work famously... if not, then I'll have to start from scratch to make something else entirely to use these solid rubber wheel loader tires... maybe we make a trade? ![]() You betcha Nathan, that steel bucket is very noticeable with its additional steel weight, but even moreso with its 2.25" longer depth (@5" total), add to that the BB's in the tires and jacking up the pressure from 12bar to 17 bar, tilting the bucket down won't lift the front tires off the ground anymore! ![]() I understand exactly what you're saying Grady, a 45* splice would definitely be better than a 90* butt joint for a smoother roll... but I don't have any extra to redo the job. Although, after wrapping the rim with each layer - I think 5 layers, then removing it from the rim to scrunch & stuff into the tire, I think I distorted the true shape I previously had & probably didn't gain much... these are crawler tires for lightweight scalers, not meant at all for what I'm trying to do. But I'm gonna try the oak donut before giving up on them totally.
I thought I would see what kind of weight could be put on these homemade foams. I put a 40lbs battery in the back of my R18 for a combined weight on the rear axle of 50lbs. I don't know how much more weight these would take but probably not 80lbs. Something tells me that if I put 80lbs+ in my Euc the tires would be the least of my worries though.
Nathan |
