Old 04-14-2013, 09:55 PM
cosworth34677's Avatar
Default Re: help! striped motor hole!!
Originally Posted by Claus View Post
Wow, that must be the new English.
ya dude i suck at type and grammar i'd be the first on to tell you i stink at try say what i mean by typing it out, im more of look at this problem i made type more then writing it down or typing it out ...but that's not the important part
Old 04-14-2013, 10:57 PM
Gotta agree with espeefan.
In a situation like this, where you have a significant casing that the motor is mounted to, its probably both easier and safer to just replace the motor than try to repair the stripped mount hole.
Think about it - if the repair cuts loose, that gear moves in the pump casing, and oops, there goes the pump. OW, thats gonna hurt (plus metal fragments in your valves/line, doh!)
If replacing the motor is that expensive, you might try a braced-mounting for pump-casing and motor, where you can clamp/strap the pump down to the brace, mount the motor with the single screw, and then clamp/strap the motor in place. One of the machinists here could make you the mount.
But I sill think replacing the motor is both the safest for the pump, and cheapest/easiest for the assembly as a whole.
WhiteWolf
