Old 04-15-2013, 09:15 PM
JDH429's Avatar
JDH429 JDH429 is offline
Default Re: Wa 500 Rebuild
Rctech, thank you
Whitewolf, I'm using some of the original parts so I wouldn't have everything to reassemble the original for use. Not sure what ill do with the left overs.
Nate, Some milling has been done to certain areas of the plate mostly on the radiuses to help make the bend.. Like the curved section on the upper rear of the front half. I do also think some flat plates could have been stamped but don't know for certain. I would think to cut costs in manufacturing the possibility is high. And to bend all the angled plate for the kit by hand seems unlikely and more probable that progressive stamping would be the typical method of manufacturing.
CDM, the original assemble may have been rushed... I def would have done some things differently.
Morockn, thank you pal. I'm anxious too. I hope it comes back together nice.
Mario, thank you! Very cool to read that. I'm enjoying each little project that all come together to finish this build. I'm no master but appreciate the comments and support, I just happen to be familiar with the process and machines used here. I am lucky to have such a nice shop. It's cool when I can use the tools for a fun project like this.
Claus, a save indeed! Thanks for commenting, very appreciated!
Jason
Old 04-17-2013, 02:27 PM
Originally Posted by JDH429 View Post
Rctech, thank you
Seeing the way you are with the average metal parts, the only thing I can see either you not being able to replicate, or not being willing to take a stab at, is the hydraulics, and any odd assemblies.
I'd be happy with her paint-stripped, w/o any of the hydraulics, and even un-assembled, if you (or someone else) were willing to assist with re-assembly. I assume a perfectionist like you is going to strip all those layers of accumulated paint off her before you even consider re-assembly, and a bared beast, less a few pieces, that I could tackle.
Let me know if thats amenable... and I'm still admiring the metal-smithing.
WhiteWolf
