Old 04-19-2013, 12:09 PM
Default Re: Good basic KH drivetrain upgrades.
You can always consider running a higher turn motor as well. Higher turn motors run less RPM, so if you can't quite get the speed you want with a reduction, you can always try a different motor, with or without an aux. reducer gearbox. You can also play with the battery voltages too.
