Old 04-25-2013, 09:17 AM
Kaf343's Avatar
Kaf343 Kaf343 is offline
Default Re: Carson track loader ESC question
Keith, I thought you'd get some replies from the who built these, but I don't think anyone really knows what kind of current the drive motors pull. If I was taking an educated guess, I'd say under hard use, I doubt the motors would pull more then 12 amps. Gear motors like this really aren't power hungry. I'd bet you would be well within the limits using a Sabertooth 2x12. The surge rating of the ESC is higher then the continuous 12 amp rating. I believe it can handle 20-25 surge amps for a few seconds. I know guys are running these with Servonaut M220 ESCs and those are rated for 20 amps. If you have doubts, the Sabertooth 2x25 would definitely handle the loader without any problems! I think you'd be very hard pressed to get these motors to pull more then 5-8 amps. If they stalled out, MAYBE they'd pull closer to 12 amps, but I doubt it.
Thanks Nathen, yes I thought the same with the 2x12. It's cheap enough that if I do have an issue I can move to something else.
I use the 2x12 in all my models including my EC300 at 50+lbs with no issues. I would say that the only drawback is the bec portion only having 1 amp.
Reg
Thanks Reg, I'm going to give it a try. What do you mean regarding the BEC. Is it something that I can overcome by adding and external BEC?
Old 04-25-2013, 10:07 AM
Yeah that's right. I have no issues with it running 4 standard servos on my EC300's hydraulic valve but in my 955 where the servos run the bucket and need more juice I had to use a bec because the power draw causes the ESC to go into protection mode. I'm sure you will be fine if you are just running servos for hydraulics. I like the control options that they have too.
Old 04-25-2013, 10:46 AM
Kaf343's Avatar
Thanks Reg, u am interested in seeing the control options that the Sabertooth has as far as controlling the left and right tracks for steering and pirouettes. I had the Liembach in my 922 and didn't like the way it drove, I changed it to a M220, that was much better. Matter of opinion I guess. Are the control options changeable.
