Old 10-13-2010, 11:25 PM
Stylin n profilin's Avatar
Stylin n profilin Stylin n profilin is offline
I'm tryin Boss!
Stylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura about
Default Re: Stock Mercedes-Benz 1850L Build w/ MFU
Looks good Paul...This thing should be really cool....
One Bus Stop Short Of The Short Bus...
Old 10-14-2010, 09:16 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Question Re: Stock Mercedes-Benz 1850L Build w/ MFU
Paul, are you going to use LiPo batteries in this truck? That is the same radio and MFU combo I have in my Bud truck that wants to start up and then die when you try to start it up. Only way I found to stop this is to keep the left stick-throttle- pushed slightly into forward. The truck will then run for the most part until you have to go into neutral where it will sometimes start its start up and then die routine. Please let me know what you come up with if you get the same results as me if you use LiPos.
Lynn
