Old 05-01-2013, 11:23 PM
dabears's Avatar
dabears dabears is offline
Default Re: My first piece of equipment - Carson Track Loader
Lucky!!! Wish I had one!!!! im sure you'll find some way to add something cool to this kit!!
Old 05-02-2013, 09:39 AM
Ulrich's Avatar
Ulrich Ulrich is offline
Ulrich is on a distinguished road
...so I'm not sure if I can run the track functions on one stick, and the bucket/loader on the other. I think that is how I would like to do it, if possible.
That´s the setup I drive. The left stick is acceleration and steering, the right one for the arm/bucket. I also used a mixer to combine the channels hyd valve (f.e.3+4) with the one off the pump(f.e.5). So if I move the right stick the pumps rpm rises proportional. That saves a lot of battery. If I want constant hyd pressure I can set the rpm with an prop channel.
bye
Ulrich
Old 05-02-2013, 10:38 AM
JAMMER JAMMER is offline
Nathan I must say when you do something you go all out. The only thing that I can is missing is the pump control to shut it down when not in use. Ed
Old 05-02-2013, 01:32 PM
Originally Posted by Straywolf View Post
Congrats on your loader i can't wait to see the build pics on this!!!
Mike
Thanks Mike!
Originally Posted by Stefan View Post
Congrats from me too, Nathan. Seeing all these nice models you guys have and the ones coming up soon (read THS Volvo) I feel really tempted to buy one or two myself - even in the wrong scale Maybe I could use the children as an alibi .
Stefan
Thanks Stefan! As much as I love to look at the THS models, there just isn't any way I can spend as much as I need to buy one of those beautiful Volvo models! I will 100% happy with much more affordable Carson! I feel very fortunate to have even purchased this one.
Originally Posted by JDH429 View Post
Nate, its finally here! That month must have seemed like 3. I'm excited for you and cant wait to see the build. Congrats!
Thank you Jason! I'm pretty excited too, but I'm thinking one thing at a time. I still have a truck to try and finish, and it's getting close.
Originally Posted by tracksntreadslou View Post
Whoo Hoo..Congrats Nate ..Nice ..Pretty pumped when that arrived at the door huh..Big trouble now because you cant top at one peice ..haha ..have fun building
Thanks Lou! I was pretty excited. I checked the tracking number for the package every day....sometimes multiple times a day. I think I will be able to limit myself to one piece of equipment. I had wanted a loader for a long time. Trouble is, now I need a dump trailer, and a lowboy to haul the loader. But I think I can be quite happy with one loader. I need to think more about my future, and save money for other things!
Originally Posted by Mitch View Post
M220 :
> Battery and motor should be no problem.
> Connect the yellow wires to the right motor.
> Connect the blue wires to the left motor.
> Look at the option table and find the correct jumper setting for
> your battery (A B C).
> Turn your M220 around and set (X) or remove ( ) the small black
> option jumpers A B C accordingly.
> Connect the upper cable "Driving" with blue servo plug into the up/
> down receiver channel you want to use for driving.
> Connect the lower cable "Steering" with black servo plug into the
> left/right receiver channel of the same stick, important!
> (you might change this after setup/programming)
> Connect the brake and rev. lights, you need them later on for
> programming.
> M220 programming :
> Turn off the M220.
> Turn on the radio.
> Hold the stick in the lower left position.
> Now turn on the M220. It will blink 3 times.
> Move the stick to the upper right position and wait. The M220 will
> blink 1x.
> Release the stick to the middle and wait. The M220 will blink 1x.
> Move the stick up. The M220 will blink and is ready.
> You only need to do this once. You might repeat it if necessary.
> Now move the stick carefully forward. The model should drive
> forward, otherwise swap the connections at the motor.
>Hope this helps !
Mitch
Thanks Mitch! I had been looking at the Servonaut manuals online, and even did some translations. Thanks for posting that here! Now I can reference it easier. Any word on your track loader? I know you bought one too.
Originally Posted by Supermario View Post
Congrats Nathan you lucky dog!
I agree with others....finish the needle first, then you can play with the spoon. Lol
Looking forward to another Sweet,Perfect build.....
Mario
Thanks Mario! Yes, I'm still working on the Kenworth. I might take a break, now and then, to at least look at the parts for the Carson. I can stare at them, and imagine it as a completed model!
Aaron, thanks! I think the beauty of this model is that there really isn't much more it needs. It will be really nice to simply build a model. The detail is awesome, it's very scale, and I like the looks of it, as it is stock. I can't say I will find myself machining any extra parts for this one. I might do a few little custom touches, but that's in the details.
bye
Ulrich
Thanks for the explaination, Ulrich! That's perfect, as I was hoping I could drive and steer the tracks with one stick, and control the loader and bucket with the other. Question now is, should pushing the stick left curl the bucket in, and stick to the right to dump it?
Thanks Ed. I didn't quite go all out. Had I done that, I would have gotten metal tracks, metal bucket teeth, and the ripper kit. I wasn't sure I liked the ripper that much. The shanks look like plastic? Wasn't sure I would use the ripper a whole heck of a lot, but it would be neat as eye candy.
Instead of having a pump shut off control, I'm going to mix the loader and bucket controls, in my programmable radio, to throttle and shut off the ESC for the pump. Should work a lot nicer. Just like Ulrich suggested. I know a lot of guys are running their hydraulics like this.
