Reg, I can't stop admiring your work, you do a fantastic job
![]() And I love those TIG welds you make ![]() How did you do those panel lines to the door?
![]() Is your TIG on it's way yet? The door lines are nothing fancy. It's just some soft galvanized steel wire bent to the shape of the door opening and glued into position. I was struggling with how I was going to make it look like there was a door there. I was going to dremel a groove all the way around but on the real trucks there is a lip on the door and the frame that sticks out so I gave this a shot. I think it turned out better than I expected. Jason, I'm always excited when I see you have posted something on your builds for exactly the same reasons! Sometimes the smallest idea that someone else has can be such a huge help. Thanks,Reg |
![]() What is that in the picture? Is that the 990 or something new? Thanks very much Wolfgang, I don't think it is better than the original, but I am quite happy with how it is turning out! Reg |
It's not the 990 , something smaller that I'm throwing bits and pieces together
Do you have proper TIG gloves Steve? If you don't they are much thinner and provide a lot better feel. I understand what you're going through though. I rarely ever wore gloves before while MIG welding steel so when I started trying this I had a hard time too. I learned the hard way though that even a tiny weld will give you a major sun burn with TIG. Probably the most frustrating thing for me is when I touch the tungsten on the work and contaminate it! I say some bad words every time I do that for sure. Sometimes I try to keep welding afterward and it's almost always a mistake with this thin stuff. I'm getting better about doing the right thing and regrinding the tungsten now though...too many wasted pieces that were time consuming to make!
Reg Oh yeah, I'm looking forward to seeing another IH Builder thread! |
No just my heavy welding gloves from stick and mig welding . I've got burned pretty bad with the mig . specially the face when getting in a tight spot on body work when the old helmet use to tick me off . just put my dark wraps on my eyes and have at it . That hood is .07" sheet the edge welding was fun gotta move the filler fast . Another build thread
