Old 05-27-2013, 09:45 PM
ihbuilder's Avatar
Default Re: 990 cat loader
started fixing another weak link today . I kept having issues with my valves sticking open and leaking The culprit p---- poor tolerances in the valve heads . The leaking was coming from a 6mm ID oring on a 5.8mm OD shaft So Made new 1's out of brass . 3-4 hours setup and tweaking and 1hr run time tops between the lathe and mill .
old
new
thanks for lookin
Old 06-16-2013, 10:25 PM
ihbuilder's Avatar
whew a little time in the shop with the cad off and the mill off Did some rearranging with the hydros and electrics . now I can use 2 bats and keep them under the hood . Also no more leaky valves the operator got a bench seat though
all nice and tucked under the hood
