Old 06-11-2013, 10:01 AM
louie r/c nut louie r/c nut is offline
louie r/c nut is on a distinguished road
Default Re: Center drilling hole in dowel?
5/8" is pretty wide what size whole are you looking to make in the rowel .
If it is walking on you you can use a body remer or an ice pick to get it started .
Also it a good idea to use a good wood bit make sure it is sharp this way you can drill slow .
Finding the center is a little tricky I do it mostly by eye you will have to dill a few as test pieces as long as you get it close and make them all the same you should be fine .
