Old 06-11-2013, 03:47 PM
Default Re: Bruder Liebherr L574
after disassembling the machine start with two servos modify 18 kg for traction wheel of the machine[IMG][/IMG]
you have to remove all the electronics and leave only the engine as well as remove caps to rotate 360 degrees
Here you can see the servo also used for the direction of the machine, I had to make a few pieces of aluminum to hold down the plastic besides the machine to fit the servos
for rear axle servo have to cut a chunk, so that it fits well and can swing the shaft
I have plastic lined to keep the putty from sticking to the servo
I bought a hydraulic kit for this machine with a 10 bar pump, a delivery hose and necessary as well as the hydraulic fluid tank, put more progress tomorrow
