Old 06-12-2013, 11:57 AM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Default Re: Conveyer Build
Here is a quick video of the initial belt tracking and tension testing. Probably going to cut a second belt, a bit wider and leave the frame width where it is. Also planning to add side boards with rubber skirts along the entire run, and a feed hopper.
Here is a picture showing how I cut the inner tube rubber band. This turned out pretty well, straight side and even. A square tube clamped down on the rubber. The inner tube is stretched around the 1/2" board that is clamped to the bench. This way I'm cutting only one thickness of belt.
http://youtu.be/BUrBJLY904o
Jim
