Go Back   RC Truck and Construction > RC Truck's General Discussion. > Get it out of your system! HERE!
Get it out of your system! HERE! You have a gripe,bone to pick, Tamiya vs Wedico or just have to let it out! THIS IS THE ONLY PLACE TO DO IT!
Old 06-12-2013, 11:51 PM
rc_farmer's Avatar
Master Builder
Default Re: Stupid mfu that keeps shutting down
Originally Posted by heavy_duty View Post
Robert and I have been plugging away at this issue.I have a futaba 10c with 2.4ghz,and I installed it in a new truck I am building and it shuts down and starts back up.I didn't give up this time,I swapped motors,batteries,and plugs.Same problem.Servoes are new.I then removed all plugs from the mfu to the receiver and plugged them in one by one.I left the plug from the mfu to the receiver labeled motorized legs,out of the receiver and MY TRUCK RUNS PERFECT.I reinstalled that plug and mu truck dies and restarts.I removed it and I AM STILL TRUCKING.No one fix fixes all,that is just my experience.Thank you Robert,
Ed
I learned something too Ed, sometimes it takes two heads working together. I am glad you are up and working.
Giving up is not an option!!!
Rob
Old 06-15-2013, 10:06 PM
Animal's Avatar
Animal Animal is offline
Animal is on a distinguished road
Hi All, I was just rereading this thread, and wanted to add my two cents. I was running an older Futaba Conquest FM radio in my Globelinner for a long time. From the beginning, I was getting some minor glitching, and after trying several different things to fix it I ended up converting the radio to 2.4 ghz. the only difference is, like some others have found, I no longer need to use the trims. When I want to change something I just move the appropriate stick to the end of it's travel. I would like to say to janderson, you seem to be somewhat defensive about Tamiya's MFU. Instead of giving people a hard time about using 2.4 ghz radios with the MFU, wouldn't it make MORE SENCE TO REDESIGN THE UNIT TO WORK WITH NEWER 2.4 ghz RADIOS!!! After all if we as customers have issues with a product, we will look for something better, as some already have. Sorry for the rant, but I have an issue with companies that don't listen to consumers thoughts, when they depend on those consumers to survive.
